Disconnection of Microsoft development board eval while using FMzPLL configuration tool
Hi friends,
I am using a flash player, but I am facing a problem with the IC.
I used the FMzPLL configuration tool yesterday and set the final PLL out to 200 MHz. All of a sudden, the Microsoft development board eval was disconnected from the rest of the system. I tried reloading the program, but failed.
I also used the demo software to do so, but all in vain. Instead, I got the following error on my screen:
Error!
nowFlash has encountered an error while
erasing the device. Please ensure that
the device is properly connected and
than try running the demo again.
nowFlash Error #:199
Please see nowFlash user guide for more
information.
                                             Back
Can anyone please help me out how to recover the IC and revert it back to its original status?
Your suggestions are awaited.
Thanks and have a good day.
Answered By 5 points N/A #141944
Looks like that you encounter this error because you hit the action to delete that device from your computer but actually there are not device connected to your computer. Actually it is not system error, the program prompt you’re this error because the computer is looking for the device but there is not device connected to your computer. If you are trying to delete device, make sure that you connect it to your computer so that next time you will not encounter this prompt. For some other errors you encounter using nowFlash Programming Tool, just always update the software. Hope this help.
