Discovery Exception been occurred when generate interfaces
I am trying to generate interfaces and business objects using the Object Adapter but I am unable to complete this task. The reason shows ‘Generating artifacts is failed’. You can see the whole attached error image so please provide a suggestion with a proper solution so that I may fix this problem. Any idea would be appreciated. Thanks in advance.
Discovery Exception
Failed to generate interfaces and business objects. Check the log file.
Reason:
Generating artifacts is failed.
