Discuss comments overlapping theme footer ?
WordPress Discus comment plug-in is works fine but we have to adjust regarding theme settings. Sometimes themes side bar due to be a wide that is why plug-in shows a comment overlapping. You have to change your theme if WordPress discuss plug-in seem to working as a overlapping. Otherwise you have to little modify you theme if you have how know about PHP. Please go to the theme editor, select a side bar file. You will see a script a side bar. Find the width of side bar of this theme and less the size of side bar.
For example if width size shows a “40”, just make least amendment not more you have to convert 40 to 35 maximum. Afterward, when you re open your website you will not see the overlapping in the Discuss plug-in.
Best regards
Notifications
