I am starting to manage my project and I am in doubts about software to use for that. I have heard that the software if BinitaSoft is perfect for that. I am going to use the Bonita Open Solution 5. 4. 2001. Am I right that it is the best bonita mode manager? Please take my question easy ad correct if there is something wrong, because I am the beginner in project manager as well as in IT software proficient using.
Discussing the best bonita mode manager for my project.
Hi Gary,
Bonita Open Solution is an open-source BPM and Workflow suite. No doubt that it is a highly competetive open source BPM. And has a good liability in open source BPM. So, you can use with out any doubt. But, you can try the latest one, which is Bonita Open Solution 5.7.2
You can also check this open-source BPM like:Â
1.jbpm –  jBPM is an open-source workflow engine written in Java.
2.intalio – intalio is a workflow engine.Â
3.appian – appian is an open-source workflow engine.
4.joget – It is also a open-source workflow engine.
5.bizagi – A workflow engine. Hope you could find your solution from it.
Thanks!
Hello Gary B Graham,
I you want to manage your business project then Bonita soft is one of the best solution provider there. You can also get training from there and also you can maintain your software solution from there. But one thing is that it is a open source platform for software production. But still you can use it for your solution as it is easy to use.
Hello Gary,
I appreciate your concern & i know now-a-days many people are using such kind of solution among them Bonita Open Solution is an open-source BPM and Workflow suite. Undoubtedly there is a high competition open source. And has a good liability in open source BPM. So, you can use with out any doubt. But, you can try the latest one, which is Bonita Open Solution 5.7.2
You can also find this sources like:Â
You can use to maintain your business project then Bonita soft is one of the best solution provider there. Training & software solution is available there but one thing is that it is a open source platform for software production. Hopefully it will be easy to use.
Thank you.
