Disk Manager missing in Windows 7
I have a window 7 64 bit original. when i turn my window on it gives me and error that disk manager is missing. i don't have the recovery DVD.
What should i do to handle the problem and don't loss my data and window .
Answered By 0 points N/A #88201
Hello Shah,
This is your original question;
I have a window 7 64 bit original. when i turn my window on it gives me and error that disk manager is missing. i don't have the recovery DVD.what should i do to handle the problem and don't loss my data and window .
Disk Manager is where you can manage the disk and volume of your hard drive. This is where you can partition hard disc and allocate space to your hard drive.
Here are the steps of missing disk manager;
Go to Start > Go to search field, type diskmgnt.msc
If this step still can’t locate disk manager
Follow this procedure;
Start > Run type SFC/SCANNOW and Enter
This will perform diagnostic System File Check and it fixes missing and corrupted files. Try also do a System Restore and Restart computer.
You may need to re-install Windows Operating System if this won’t help.
