Display driver not responding error
My System home hangs frequently and restarts. some times it gets display driver not responding error and needs to be restarted. Please solve this problem.
OS : Windows Xp
OS : Windows Xp
This means two things
1st case
2nd case
Once the installation of the update drivers is done, reboot your computer and it will solve the issue.
Hi Uaskme39,
Dear it is a virus attack on your system.
Kindly first scan your computer for viruses with latest and updated antivirus. You should use "Panda Antivirus 2013 Pro" it provides a large definition to fight against the virus.
You can download it from here.
https://www.pandasecurity.com/usa/homeusers/solutions/antivirus/
After install this software you have to restart your computer, and then scan all of your hard drives.
It will take a very low time. After this your computer will be very light in speed. No burden of virus will remain.
It is only the virus problem which you are facing.
Thanks
Hello dear,
This is a very common error. You cannot remove it with any software. It is a hardware problem. It seems that your RAM is creating the problem. Just check your RAM deeply for any damage. Sometimes, dust creates these problems. It creates black carbon on the edges of the RAM. Remove your RAM from the motherboard, clean its edges, and put it back into the slot. Also, check if the RAM is generating too much heat. If you notice this, replace your RAM immediately. Thanks.
