Display error after working normally
My system is open normally and run 10 to 20 minutes shows there is no display but the back ground music and sound we can here with earphone.
What will i do for this error?
Hi Ayswaria,
It is just your screen monitor that is not properly connected.
Check all the wires such as the VGA Cable and also the power cord of the monitor if they're properly connected.
Try also plugging the power cord of the monitor to another outlet.
Hope it helps.
Hello Ayswaria,
Please, be sure that all connection is properly connected. If you are sure and still have problem, then, no doubt, that’s a issue of power supply failing. Then, you need to replace the power supply to recover the problem.
The power supplies also can be rebuilt somewhere.
So, don’t throw it away. You can sell it.
After replacing your power supply, the issue will be solved.
No tension.
Have a great day.
Thank You.
Notifications
