I heard that this Display fusion allows you to control more than one monitor and then it can be split to one another and more. I want to use this Display fusion but do you think it would be possible to connect to monitor with different brand?
Display Fusion with different Brand of Monitor
Yes, it is possible to connect to other monitors that have a different brand with your primary monitor. However, the experience with connected, different-brand monitors is going to be a little different with the recommended same-brand monitors. Expect lag issues like slow screen-refreshing. It is still recommended to connect multiple monitors with the same brand. But if you have no choice, then connect them. The experience will be different, but it will not greatly affect the whole multi-monitor experience. If you have the option to use alternatives, you can use other programs like Ultramon, Zbar and Dual Monitor Taskbar, however the last one will only provide added functionality on dual monitors.
