I am having a Samsung CCTV DVR which is used to track the office. I want to stream the feeds to a website and in turn it can be accessed through a login password, is there any web based software that will help me to display Samsung DVR stream to webpage, Please advice on how to get this done. Thanks
Display Samsung DVR Stream to webpage
Hello, Conrad! I have found that you have Samsung CCTV DVR and you want to use it as a stream to the webpage. Well, you can use a software from samsung’s website http://www.samsungsecurity.com/product/product_view.asp?idx=6275 and you can see the software description as well as a guideline. Hopefully, you will enjoy it. Have a good day!
