Displays 800f0829 Error While Installing Microsoft
Give detailed knowledge of the 800f0829 error? Explain the steps to resolve the error code and the cause of this error message?
When the user downloads the Microsoft application and tries to install the application then an error occurs named 800f0829 error. The reason behind the occurrence of the error code is the corrupt Microsoft office file, improper Windows firewall, the user is trying to install a partial solution, and the previous installation of the computer had not removed properly. The steps to fix the error code are as follows:
• Repair the Office app
Step 1: Go to Start and open Control Panel.
Step 2: Click on Program and open Program and Features.
Step 3: Click on the product which the user wants to repair.
Step 4: Click Change.
Step 5: Select Quick Repair and click on Repair.
• Use Task Manager to close the running tasks
Hold Ctrl+ Shift+ Esc to open task manager. Click on the Process tab and clear every task that is running in the background.
