Hi experts!
I have used an older Heidenhain TNC 2500c. When I have tried to start the machine I have faced a problem. This error message processor check error B keeps showing. Can anyone help me by providing solutions? Thanks in advance.
Displays processor check error B
Heidenhain TNC 2500b is what you are talking about and have probably mistyped. The error has occurred because of contradictory or incompatible inputs.
Do not worry, the problem can be solved.
In case of the mentioned problem, you should alter to the “PROGRAMMING AND EDITING”.
Operating mode. The error is generally found either in the block with the displayed block number or in a previously executed block. Correct the error and then take the operating mode to “full sequence” and restart.
If further problems occur, then contact the machine manufacturer’s customer service or an IT expert.
Good Luck with you.
