Distinct Features Of HTC One ME Smartphone
What are the distinct features of HTC One ME Smartphone which happens to be a dual sim with 5.2 inches display screen? Can you also walk me through the various features systematically with pictures if possible? What makes this smartphone so extraordinary from other dual sim smartphones perhaps with similar display size? Lisa is my name. Thank you.
Answered By 590495 points N/A #131783
HTC One ME is a 4G device operating on 2G, 3G, and 4G bands using GSM, HSPA, and LTE technologies. It was announced on June 2015 and released on July 2015. It measures 151 x 72 x 9.8 millimeters and weighs 155 grams. It uses dual SIM cards (nano-SIM, dual standby) with fingerprint sensor. It has a capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution.
It supports multi-touch with HTC Sense UI 7.0. It runs on Android 5.0.2 Lollipop powered by Mediatek MT6795 chipset, octa core 2.2 GHz processor, and PowerVR G6200 GPU. It supports microSD expandable up to 128 GB. It runs on 3 GB RAM with 32 GB internal storage. The primary camera supports 20 megapixels at 5376 x 3752 pixels with dual LED flash (dual tone), and autofocus.
The camera supports geo-tagging, HDR, face and smile detection, and panorama. The camera can record video in 2160p at 30 fps. The secondary camera supports 4 megapixels (1/3'' sensor size, 2µm pixel size) and can record video in 1080p at 30 fps with HDR. It has Bluetooth 4.1 with A2DP, and apt-X; GPS with A-GPS, GLONASS, and Beidou; NFC; microUSB 2.0; and Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot.
It has built-in compass, proximity, gyro, and accelerometer sensors. The pre-installed browser supports HTML5. It doesn’t support Java. It runs on non-removable Li-Po 2840 mAh battery with standby time up to 598 hours on 2G and 626 hours on 3G. Talk time is up to 23 hours on 2G and 13 hours on 3G.
