Distinct Features Of Peel Smart Remote (Galaxy Tab)
What are the distinct features of Peel Smart Remote (Galaxy Tab) as compared to other similar Android apps? What are the benefits of using Peel Smart Remote (Galaxy Tab)? Are there any challenges which are of the likelihood to be encountered when it is installed on Samsung Galaxy Tablets and what is new on the Peel Smart Remote (Galaxy Tab)? Thank you.
Answered By 590495 points N/A #189780
I’m not sure if Peel Smart Remote (Galaxy Tab) is only designed for Samsung Galaxy tablets though it bears the “Galaxy Tab” in its name because there are two Peel Smart Remote Android applications available on Google play store. Anyway, the Peel Smart Remote (Galaxy Tab) Android app changes your home entertainment experience by incorporating live TV content discovery and universal device control into an easy to use phone application.
This application allows you to use your Smartphone as a remote control using the built-in IR blaster on your device. Peel Smart Remote (Galaxy Tab) lets you control your set-top box, TV, Blu-ray, DVD player, Apple TV, Roku, audio system, and more. Based on your preferences, you can enjoy personalized show, movie, and sports recommendations. Peel Smart Remote (Galaxy Tab) allows you to set or place reminders so you can watch a show later or program your DVR.
You can also pick your preferred TV shows so you will never miss a single episode. It also allows you to customize your channels to be able to meet your dish or cable package. The latest version is Peel Smart Remote (Galaxy Tab) 4.0.3 and it requires Android 4.0 Ice Cream Sandwich and later. Visit Peel Smart Remote (Galaxy Tab) to download.
