Distinction features between Fujifilm FinePix SL300 and Canon PowerShot SX260
Which of the two digital camera has a good feature and good to use for an occasion and which has better image result when having a shot to a particular place?
Hi ,
Both the cameras are an equally good choice.Â
The selection of a best camera depends on various factors like your required budget, the required ISO variations, lens aperture , zoom etc. Please note that the number of megapixels is not a factor to be considered.
Sx260 has a 3200 iso compared to sl300's 1600
Lens aperture, focal length are almost comparable and negligible differences only are present.
Another major option to be considered is the HD recording . SX260 offers 1080p (better)recording while sl300 offers 720p. Also canon sx260 uses CMOS sensors whereas Fujifilm sl300 uses only ccd.
Price may also be a tradeoff as there is a considerable differences in price. Overall Canon Powershot sx260 seems to be a good buy although fujifilm will be a cheaper option.
Hope this helps.
Regards
Powel Jedei
They say that beauty is in the eyes of the beholder. Thus, the best way for you to determine which of the two you consider best is by looking at their details and choosing the one that you consider best for yourself.
You can read in-depth reviews of the Fujifilm FinePix SL300 at the address http://www.photographyblog.com/reviews/fujifilm_finepix_sl300_review/. The review includes pictures of the camera and also a sample of photos taken by the camera.
For the Canon-Powershot-SX260, the link is http://www.photographyblog.com/reviews/canon_powershot_sx260_hs_review/. It also has a comprehensive review of the camera. After you have read the reviews and weighed what you consider best in a camera, then you can be sure to make a sound judgment.
My recommendation would be for you to go for the Fujifilm FinePix SL300 as it has enhanced zoom features as compared to the Canon-Powershot-SX260's aperture size.
