HELLO !
I need some guidance regarding drive manager windows sidebar gadgets.
I install drive manager but now it is not working properly. If the drive is 30gb empty before I deleted anything and after deleting 1gb data it will remain showing 30 GB, what might be the problem is ? And how I can uninstall the gadgets ?
Dive manager windows sidebar gadgets
H there,
I think your gadget is working properly and can read the right data from your hard disk. Have you heard about resetting or restoring process for the gadgets? Go to control panel the click appearance and personalization under the desktop gadgets. You will see the “restore desktop gadgets installed with windows and this will bring up the desktop gadget window then your gadgets are good as new. Hope this information helps.
