Division between Block Offset, Index and Tag.
If Cache Size is 64 KB, Block size is 32 B and the cache is Two-Way Set Associative. For a 32-bit physical address, then give the division between Block Offset, Index and Tag?
1. The block size is given as 32 B, therefore we can calculate the block offset as;
2^(block offset) = block size = 32.
Hence, block offset = 5 bits.
2. Cache size is given as 64 KB, therefore we can calculate no of blocks as;
No of blocks = cache size / block size = 64 KB / 32 B = 2048.
Because two way set association is used,
No of lines = 2000 / 2 = 1024.
So we can calculate the index size as;
2^(index size) = 1024.
Hence, index size = 10 bits.
3. Because the physical address block is 32 bits long,
Offset + index + tag = 32 bits.
Hence, tag = (32 – 5 – 10) bits = 17 bits.
