DivX – Media player pins and codes
I can't play any DivX movie – I have only error message "pins are not connected". What can I do? I need some media player pins and codes? Where can I find it?
Hello carr,
I have read your problem. Please don’t panic with this. You don’t need to download pins or code. You can download new version of divx player. The div video format is a widely used format and most of the players are compatible with this. Download
any software you want according to your operating system. If you want to download divx player then the following link will help you.
http://download.cnet.com/archive/3000-2139_4-10316156.html
Thank you
Notifications
