Dll file error with MSVBVM60.DLL message
While installing a DEC software I came across a text that reads “a required Dll file,MSVBVM60.DLL.was not found..
This indicated that there is a DLL file is missing from your Windows Folder in drive C. There are few things that you should try
Run Ccleaner and clean all the registries by using it. It removes all the unwanted registries that keeps attaching themselves with other files and causing problems like that.
This might be an indication that your windows is somehow corrupted but I won’t recommend you to install a new copy. So better leave it as it is and proceed to next step.
You can simply download the missing file from any of the two links.
msvbvm60.dll free download link
or
https://www.dllme.com/dll/files/msvbvm60_dll.html
Just download it and keep it in Windows/system32 and it will solve the issue
Indeed, it solve the issues that creates while im downloading the DEC software in my computer..Thank you.
