caspian zec
30 points
Posted on - 09/05/2012
Hello guys, I wonder why every time I opened my adobe flash player portable creator it show an error message: dll file is not available. Please help me guys on how to fix this soon. Thanks in advance!
Dll file not found in my Adobe Flash Player portable creator
Dear Caspian,
If you are getting that error in a portable flash player then it means some file has been deleted/gone missing.
I would suggest just download a portable version from a new source.
Try this link:
http://netscooling.blogspot.com/2011/05/adobe-flash-cs3-portable.html
Scroll down and click on the light-blue download button.
A new tab will open, wait a few moments for the download to start…If it does not start automatically then click on this on this link: https://mac.filehorse.com/download-lg-pc-suite/
Wait a few seconds and then your download will start.
Use that version of adobe flash portable creator.
Hope you don't get the error after that.
Regards
