I installed DLL Files Fixer yesterday and I used it to fix the registry errors and other errors which I had on my PC. I have a paid license of the software. I booted my PC today morning and got the disk check. It fixed a lot of errors on my PC and DLL Files Fixer's license was also removed. What should I do next?
DLL Files Fixer almost damaged Windows, what to do next?
I don’t think you should be worried because you can restore the license when you reinstall the application. I know typical applications such as yours have lifetime license. I mean, when you purchase the license you usually get 1 year free updates and then after that if you no longer wish to update your software, the existing license you have will continue to work.
In your case, since your computer fixed a lot of errors during startup, your DLL Files Fixer software may be included among the damaged files. Just reinstall it and enter the license again. Click Start, Control Panel, and then Add or Remove Programs. Select DLL Files Fixer from the list then click Remove or Uninstall.
After that, click Start, All Programs, Accessories, System Tools, and then select Disk Cleanup. Select drive C then click OK. Check Setup Log Files and “Temporary files”, click OK, and then select Delete Files. Restart your computer then install DLL Files Fixer back. Once it is installed, enter the license again and it should be back to normal.
