Is dll suite program similar to errorteck software?
Hi!
I just downloaded a dll suite program. They say it has a windows error fixing tool, thus it speeds up your window OS. I was just wondering if the dll suite program similar to errorteck software? I've read from one website that with the error fix tool of errorteck, computer errors can easily be fixed by just one click. Are they the same? If not, which one is better?
Answered By 0 points N/A #180652
Hi Hugh,
DLL Suite is a tool for repairing System .DLL files that can be corrupt or missing in the computer. However, reviewers would say that it is not really designed to improve system performance since DLL are part of a Windows file. Windows files are needed for software to run and from the Operating system to run normally. It can only detect .dll system file problems and just repair them but will not be able to replace or install new .dll files.
Answered By 590495 points N/A #325754
There are many applications on the internet that offer solutions to fixing computer errors and there’s no problem trying them out on your computer as long as it is virus free. If you are not familiar with the software or tool you want to try, always scan the installer or the file with an updated antivirus once you downloaded it on your hard drive.
Most of these applications are offered as trial or demo which you can install and use for a limited number of period. Once the trial period expires, the program will automatically stop working and you have to purchase it to continue using it. If you have no plans of buying it then you have to uninstall it from your computer.
One software you can try is PC Tools Performance Toolkit. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. The program offers a “one-click” optimization button on the main tab which I haven’t tried though I’ve been using it for a very long time. I prefer optimizing my system manually than with a one-click button.
