DllRegisterServer Failed:error Code 0x80070005 Is Fixed.
I am facing the error code 0x80070005 and unable to resolve it which shows that dllRegisterServer failed will this error code 0x80070005 be resolved or I have to meet the operator for this issue.
Answered By 0 points N/A #293322
There is a very simple solution for this problem just open command prompt just type this following command and reboot the system the dllRegisterServer failed with error code 0x80070005 will remove automatically.
”C:\Windows\SysWOW64\regsvr32.exe”and then write this ”D:\ProgramFiles\CA\Erwin\9.64\1\32-Bit\EAL.dll”
If the error persists then try logging into the administrator’s account and type the above command once again, and you can disable your firewall settings, this can also work.
