nadiajgoff
30 points
Posted on - 08/04/2012
Hello experts,
When I want to browse in the internet, the net connection just stopped after a few minutes.
It states I am linked to my Wi-Fi network; however there is "limited or no connectivity."
When the error occurs, the entire thing on the network just loses the connection at the similar time.
In my home, i have one PC, one iPod touch, one Mac, as well as 2 iPhones and all are connected to the wifi.
I need to find the reason and a solution. Please help me.
Thanks in advance.
Error: DNS and IP conflict errors.
techyboy
You have not fully describe your question here. Which type of router you are using? Which type of Internet Connection do u have? What is the status of other devices are they working fine or not? Please give details. However, you can find the issue by checking the DHCP Lan setting of your router, Check your external ip is obtained, Ping to the DNS Servers of your internet providers. Ip schemes of both external and internal (LAN) should be different. Obtain the DNS server automatically from your net provider if it is obtaining the Ip through DHCP.
Dear User,
Your question is a bit unclear. but nevertheless, try these steps,
Assuming you are having this problem mostly with the computers, first make sure that you have successfully configured your router according to your Internet Service Provider (ISP) .
And make sure your wifi settings are correct.
And also try using a different DNS, for an example you can use OpenDNS.
https://www.opendns.com:443/
Thank you.
