Dns Viewer can’t connect to Server and ping Client System
I'm getting too many errors in my DNS event viewer, I've pasted the error below. Please give me a solution to this type of error occurred, resulting that all of my clients can't connect to ping server and the server cannot connect to ping Client System and all of the sharing resources was not working.
Answered By 0 points N/A #162434
If you want to solve your DNS server problem then at first you need to check your DNS event log. For checking this DNS event log, you need to open the DNS console and then the open event viewer and then click DNS events.
Then check the error event ID. I have found a website for you where you can check your error DNS event ID and also can resolve your error problem. So,  find out the solution for your DNS event viewer.
