Do HDMI connection needs a special driver?
I have HDMI connection from my laptop to my TV. I want to maximize my HDMI connection to it's full potential. I just want to know if there is a special driver for my HDMI connection or is it supported natively by the operating system which is in my case Windows 7?
Best Answer by Luke Dan
Answered By 5 points N/A #120538
Hello Thompson
Regarding about your inquiry. Yes as long as your laptop can detect your TV that's fine. No need of drivers for optimization. But you can enhance the display though.
You can check on your Display settings then click on advance settings. In there you could actually enhance the display in your TV optimizing your visual experience.
You can adjust the brightness and settings. Just choose the desired settings then apply. It would greatly enhance it to it's fullest potential.
Answered By 0 points N/A #120539
Yes it is supported natively by operating system so no need to install any drivers just to connect your laptop with your TV you need to follow this:
Make your TV close to your Laptop so your cable from laptop can connect to your TV  easily then connect between end of HDMI cable to HDMI port that is available in your video card of your Laptop and then connect between  the other end of HDMI cable to open HDMI input port that is available on TV then Switch on your Laptop and TV and using your Remote control change video mode into HDMI connection.
Hope these steps help you.
