Do I have KERNEL or DISTRO?
I am using Linux operating system but I am not sure that which version I am using. Is It KERNEL of DISTRO? How can
I find out that which version am I using. I am really new at Linux.
Hey Spencer!
If you want to know the Kernel/distro version of Linux then there is a simple solution for this. You can use "uname" command to know the version.
Here is an example "uname -arv" or "uname -r"
The above command well tell you kernel or distro version of the Linux.
This is a simple way to find out that what version of your Kernel or distro have. I have also used the same command to know my kernel and distro version.
I hope it will help you to know the kernel or distro version of your Linux.
Thanks
Tunacao Caaron
Hi there user:
Type this command ($ cat /etc/*-release) when you get to the shell prompt, if you want to find if it’s a Distro version.
Type this command ($ uname –a) and/or ($ uname-mrs) when you get to the shell prompt, if you want to find if it’s a Kernel version.
Here’s the output for Distro version: DISTRIB_ID=Ubuntu DISTRIB_RELEASE=7.10 DISTRIB_CODENAME=gutsy DISTRIB_DESCRIPTION=Ubuntu 7.10
Here’s the output for Kernel version: Linux 2.6.32-5-amd64 x86_64
Thanks for asking via techyv.com
Best regards,
