Do I need airprint built into a printer to print from iPad
I would like to print something of my IPad. Do I need to find a printer that has built in Airprint support or can I down load drivers
Dear Julie,
Yes, you will need a printer supported by Airprint.
You can look and see if your current printer is Airport supported. Also make sure your mobile device has the latest updates provided. You also need to make sure it is connected to the same network as your device is connected to so that it will work.
Here's the list…(It's very long.)
https://support.apple.com/en-us/HT201311
Good Luck!
Dear User,
When it comes to print using your iPad the options get pretty slim. The official answer to print you documents from you iPad is to sync them with your pc or mac. And print them there.
But here are so many third party apps that allows you to print from your iPad. There are many but,
Air Sharing HD is the best app for this.
And yes you will have to use an application to have your documents printed directly from your iPad.
below is a link you can refer to,
Thank you
