Do I need internet connection for at t homeview?
I downloaded at t homeview but it does not seem to work. What could be the problem? Do I need internet connection when using at t homeview?
Hello Ivonne,
Yes you need to use an internet connection to utilize at&t Homeview. Otherwise it fails to connect to its server from where it will deliver you stuff you want to see. So please connect it to the internet and it will start working without any problem.
Of course you will have to be online for it to work. So make sure you are connected to the internet with a strong and reliable network. You can also check with their customer support page and get any further help concerning other matter in future. I hope this information helps you out.
Thanks
Amos Marie
