anonymous
7060 points
Posted on - 05/02/2013
I have the 16 GB Nokia N8 that has a 256 MB RAM, Wi-Fi 802.11 b/g/n, UPnP technology, 680 MHz ARM 11 CPU, Broadcom BCM2727 GPU and Symbian 3 OS. Do I need a Nokia N8 wifi sharing software to make my phone a hotspot or is there a built-in option for that?
Do I need a Nokia N8 wifi sharing software?
To turn on your Nokia N8 WiFi spot, you need to download WiFi sharing software.
I will highly recommend Joikuspot. With Joikuspot, you can enjoy WiFi access in your own since it has its own security built-in feature to block unknown connections.
Just to quickly note that if you are using an anti-virus program then the app won’t work.
If you want to turn your N8 into a 3G, hotspot, you have to download a joikuspot software on this site. It has a security feature that you have to set to enhance your internet security.
After installing, you can follow the following steps to enable it.
Click internet, >turn phone into a wifi internet gateway, then click on the computer to connect to joikuspot network.
