Do I need a Plugin in mastering music iPad?
I want to do music in my iPad. I haven't tried yet. What is the best mastering music for iPad? And do I need a plugin in mastering music iPad?
I don't know what type and version of ipad you are using and what kind of file format your device support. So you need to check the format that is supported by your ipad and you can convert your files in that format to run them on your ipad.
Smith Thompson.
There are many applications which provide the capability of mastering music on your IPADs. Just go to iTunes and find out the most appropriate application as per your own requirements. All the information is provided plugins and all in the applications. For the good ones you just may have to buy them as they are not free. I just found out one here is the link
https://itunes.apple.com/us/app/a.p.s.-musicmaster-pro/id441595661?mt=8
xoxoxo!!
