Do I need a Windows CE WiFi software to share my internet?
Hi guys.  I plan on getting the 16 GB Nokia Lumia 925 that has the Qualcomm MSM8960 Snapdragon chipset, Dual-core 1.5 GHz Krait CPU, Adreno 225 GPU and Microsoft Windows Phone 8 OS.  Is there a  way I can share my internet via WiFi or do I need a Windows CE WiFi software?
Answered By 0 points N/A #141150
Hi! elsietbrown,
I have understand your problem and  there Is a easy way to share your phone's  internet connection. Follow the step by step procedure and you are done.
1."Turning your phone into WiFi hotspot "
 To access internet sharing :
Then tap internet sharing on
Then set the option for your Hotspot : ( Hotspot name, password )
Its done
Now you can Connect your Laptop , any other phone to internet by using WiFi hotspot of your Phone.
