Do Inkjet Cartridges Dry Out? What should I do to prevent it?
Asked By 160 points N/A Posted on -
Hey everyone,
I have a Printer that I use occasionally, and I think the Ink Cartridgewould dry out if I don’t use it much. Do Inkjet Cartridges Dry Out, and what can I do to prevent it?
Answered By 0 points N/A #200400
Technically speaking, the Inkjet Cartridges do not Dry Out. The Printer becomes incapable of Printing when it is not used much, as the Nozzles get clogged by the Dried Ink.
To prevent this from happening, you must print a test page once a week, so that the Nozzles remain functional. You must also switch off the printer only when the Nozzles come back to the home position.
If you are too much worried, you can replace the Former with a Color Printer.
