Mickhel
70 points
Posted on - 10/06/2011
My pc is running very well . Brand LG Windows XP . I am very happy to use my pc.
I do not use it properly . And about it fluently I do not know . Now a days I am
suffering a simple problem which is include Recycle Bin . When some folder
or data delete I know it is go out box that is Recycle Bin , But when neede
thats folder I do not find it Recycle Bin . Where could I find any deleted data.
Samol
Paul21
Do not find any folder in Recycle Bin
Hi, what you get is because, you may be are choosing to delete your data permanently, in this case data will not be held within the Recycle Bin , as you said, instead it will be deleted permanently . But, of course there is a solution, if you delete a file and you want to recover it, the best way is to use one of the many programs in windows that allow to recover data from the hard disk, personally i strongly advise you to use "recuva", i admit it is the best program i have seen in this field , it will take you a couple of clicks and some patience and you will get all your files back ,and you will astonished how good it works!!
this is the link for the program !!
http://www.piriform.com/recuva
hope this is helping!
thanks
olebg
There are 2 reasons that the folders don't appear in the recycle bin. If you are pressing shift+delete the files/folders are pernamently deleted and you can only recover them with 3rd party software like recuva or easy recovery. The second guess is that the settings are set to delete files/folders pernamently, so go to Recycle Bin proporties and remove if checked "Do not move files to the recycle bin"
