While accessing to PDF files from a web site using IE 8 for Microsoft Visual C++ .I get an error message saying that an application has terminated in an unusual way.
How could I solve this problem?
Error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program:C:program File (x86)Internet Explore iexplore.exe
This application has requested the runtime to terminate it in an
unusual way.
Please contact the application's support team for more information.
Elanpaza
Do not get access to PDF files
Hello Elvis.
First let me assure you this is a common problem and it has one definite solution. So don't bothered so much. It shows this message because a redirected data folder problem. When you are trying to open the PDF files from IE then it request a redirected dada folder and for this network path which is responsible for holding that specific application data that uses a path named unc path. This very path causes the main problem as Adobe reader incorrectly parse the application and hence its shows the error message.
There is a solution for this. Although Adobe has been already updated their versions regarding this. First try to update your Adobe reader version. the best version is Adobe reader 9. If you have adobe reader 9 installed in your machine i guess the problem will be solved.
If you have already installed the latest updated version and still getting error message. Then go to regedit. you should run the program as an admin. Then change the %User Profile%/Application data to /Application data/roaming. It will solve your problem.
Let me know if the problem still arise.
All the best!
