Do not get a good print from printer.
     I have a cannon ip2772 printer. Some times it cannot work properly and I cannot get a good print.
It may be occurred by the problem of printer head. It is a common problem of any kinds of printer. If you know about head cleaning process you can easily solve the problem. You don’t really have to open your printer head to clean; there is a simple option in to easily clean it in your computer (if your printer driver is installed) when you are in a print window click on then another window will come then click on the properties and then go to maintenance and click on clean or cleaning to clean your head. After cleaning the head you can check the color, if all the color cannot seems accurately you may need to a deep clean. Thank you.
If you sometimes experience problem using your printer, it would be better to check the age of your printer and how long it was since you last let it check by a certified technician. If the printer is already counting years and it’s been a while since you last bring it to a technician for a check, this would be the right time to let a technician check it. It’s maybe because of wearing out parts because it’s getting old.
If the printer is quite new then maybe you only need to reconfigure it again. If the problem has to do with the quality of the print like for example the print out looks blurred or unclear, you may need to re-align the printer. I’m not sure if re-aligning a printer is the same with all other printers but the procedure is usually found on the manual that comes with.
Hi guys, your method of explanations were very lucid and receive my best wishes. I am very anxious about my printer, I tried whatever I can but not fortify. Garry Bross, I have done what advice you have given but not worked, at the last moment Sharath, according to your advice I have checked, it was not old, it’s a new one. So as a remedy, I have re-align the printer, after that I saw with surprise that I was working properly. When I saw this problem has disappeared, my face beams with a smile. Now, I am free from all cares and anxieties. I could fix any problems about printer and my work would be done early because of your advices. Thanks guys and Techyv.com for your helping hand.
