I use Mozilla Firefox browser and it remembers history all the time. I do not want it to remember history but I have no idea about how to do it. So it is very inconvenient for me. Please let me help me solve this problem. I tried reinstalling to solve the problem but it did not work out.
Arman Hamilton
Do not want firefox to remember history
Go to Tools Menu > Privacy Tab > History – Firefox will > Choose Never Remember History from the Drop Down Menu > Click on OK.
Okay reinstalling does not solve the do not remember history problem,rather than it will set up to default and will remember history. You can easily set up your Mozilla Firefox history setting.There are several options for you.
Please open your Mozilla Firefox browser and find out Tools tab on right upper side, click on it.
Then click on Options located below. A pop up window will appear.
Then click on Privacy located middle upper on the window.
Then from the dropdown menu click on never remember history or the option you like.
Finally click on ok located below to confirm your history setting.
There is a link on the window like this: clear all current history, if you want to clear your previous history then click on it, then click on ok.
And finally click ok located below to complete your set up and exit.
