Do pharaoh gold games needs product key?
Hi experts,
I have an android mobile phone, I want to download some games and applications including the Pharaoh Gold game. Is it compatible with an android mobile phone and do I need to produce a product key just to install it?
Thanks, need your help guys.
Best Answer by Carl Jack
Answered By 0 points N/A #152748
To know if an application is compatible with your Android phone, you'll just have to go to https://play.google.com/store. Register your phone there and search for the app you would like to download. Now, there are only two types of application, the free ones and the paid ones. For the free ones, you can download them anytime and for the paid ones, you will need to pay first before you can download them but you don't need a product key anymore once you pay for the application since it will automatically appear on your account.
Answered By 10 points N/A #152749
Hello Ney,
I do not think you will need to a product key to play the Pharaoh gold games unless you want to play the highest levels. You can be able to play these games for free at a lot of the Top casinos in the UK, for instance Paddy Power, Mecca as well as Sky Vegas.
You can either choose to go to the Casino or you can decide to play the games online from the comfort on your own home. To get more details on which games you can choose to play according to your preference and what games can be supported by your phone, just check out this site: http://www.onlinegaminatorgame.com/slot-games/pharaohs-gold-ii/
Hope this helps.
Carl
