julio zerbe
Posted on - 05/22/2013
Hi! I want to improve my web page. I've been having a hard time setting my albums to have a scroll feature. Are there any css scrolling albums which can be found on the internet? If there are none, can you help me out with this problem? I need css templates that would help me control the layout of my albums.
Do you have any css scrolling albums?
Hello Julio,
There are very less cs's scrolling albums available on the internet and those available may not fulfil your requirements, so it is always better to develop your own scripts as per your requirements.
You should refer to the sample code snippets attached to this comment. These are the perfect examples of css scrolling scripts . You can make use of these and make your webpage look alive.
Hi Julio,
I can relate to your concern when I was still new in web development. I can suggest you to use this decent and stylish photo album with scrolling feature called Image Flow.
You can view its demo here and download its code here. As a web developer, I  would really suggest you to learn how to use Word Press because it has CSS Templates which you can use and edit yourself.
