Do You Know About Microsoft Lumia 535 Dual Sim?
If I am not considering Microsoft Lumia 640 XL black then should I consider Microsoft Lumia 535 dual sim? Is Microsoft Lumia 535 a smartphone worth to buy?
Well, if the smartphone is worthy or not, it particularly depends on the user instead of the viewers. Every person has its own taste. Each product has its own pros and cons whether it is an android, Microsoft or apple. Taking those pros and cons into account, you have to decide whether the product is worth to buy or not.
Having 5-inch display with 540*960 pixel screen resolution contains windows 8.1 operating system as default and is not upgradable to Windows 10. Having 5MP back camera and 5MP secondary camera, it has 1905 mAh Li-ion battery and is not LTE supported also. In conclusion, Lumia 640 XL black is a better phone as compared to the Lumia 535. But if you want to buy a cheaper phone with some extra features, then you can opt for this choice.
The Microsoft Lumia 535 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams.
It uses dual micro-SIM cards and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3. It runs on Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with f/2.4, 28mm, autofocus, and LED flash featuring 1/4″ sensor size and geo-tagging. It supports 480p video recording at 30 fps. The secondary camera supports 5 megapixels.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic support; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in proximity and accelerometer sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 336 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in gray, blue, orange, green, white, and black colors.
