DO You Know How To Install Corel Draw X5
I am a graphic designer student, and I want to install Corel draw x5 on my system. I have downloaded the setup but not able to crack it completely. How to install Corel draw x5 on my computer?
Corel draw is used for the making logos, graphics and much more. It is used by generally graphic designer students and organizations to make various graphics. It is very easy to install Corel draw x5 on your system. Just make sure you don’t have any eXPired or corrupted setup. Also, make sure that your system doesn’t contain any virus or malware.
These are the following steps to know how to install Corel draw x5 in the system –
1.) Double click the setup and run the application. The setup will ask you for the serial number and product key.
2.) Open the setup folder and there wither you will find a screenshot or a file which contains the serial number and product key. Copy and paste the serial number and other required fields in the pop-up window.
3.) Select the license agreements as I agree and click next. Now, fill up your name and organizations in the next pop-up window and click next.
4.) Start the installation process and wait for the program to install.
If you need to use CorelDraw Graphics Suite X5 and install on your computer, check the system requirements first before downloading and verify that your computer meets those requirements. CorelDraw Graphics Suite X5 supports Windows XP, Windows Vista, and Windows 7.
It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor, 512 MB RAM, 750 MB free space, 1024 x 768 minimum screen resolution, and DVD drive. For browser support, Microsoft Internet Explorer 7 and higher is supported. If you will be downloading a trial version, check the trial period to learn how long you will be using the application for free.
After the trial period, the program will stop working and you need to purchase it to continue using it.
