Do You Know How To Reset Blackberry 9900
I own a blackberry 9900, and it is facing some issues. It hangs sometimes and does not work properly. I want to reset my phone. How to reset blackberry 9900?
When you own a phone, you should always know how to reset and reboot it. Because sometimes resetting a phone often helps you in fixing many issues without any technical help. There is how to reset blackberry 9900 –
1.) Press alt key, a key and delete key and hold them together for some time until the phone shuts down.
2.) After some time your phone will start and you will find that your phone has been reset. These three keys are responsible for resetting your phone.
If you have a BlackBerry Bold 9900 Smartphone, here’s how to factory reset your phone. On your phone, press and hold “alt,” “aA,” and “del” buttons simultaneously. This will cause the phone to shut down. When the phone is now off, release the buttons. Wait until the phone restarts. Once the phone has restarted, the reset is complete.
Before doing the factory reset, make sure to backup all your files to your memory card and then remove the memory card from the phone before doing the actual reset. When you factory reset your phone, everything in it is wiped out including your contacts except if your contacts are stored on the SIM card. The SIM card is left untouched during the reset.
