Do You Know How To Take A Screenshot In XP?
I wanted to store some stuff on a website which cannot be downloaded, so I wanted to have some screenshots. Is it possible to take screenshots of Windows XP? If it is, then how to take the screenshot in XP?
Answered By 0 points N/A #306063
It is possible to take a screenshot of XP, Vista and any other windows. Usually, people use snipping tools to take the screenshots, they select the particular area and then capture a screenshot and save it. But there is another easy way to capture a screenshot without selecting the snipping tool all the time.
Just a single step and your screenshot will be captured. Press and hold windows and print screen key from the keyboard, and your screenshot will be captured in the default pictures folder of your computer.
Answered By 590495 points N/A #306779
The easiest way to take a screenshot of your entire screen in any operating system is with the PRINTSCREEN button. If you have something on your screen that needs to be captured, just press on the PRINTSCREEN button on your keyboard. The snapshot will then go to the clipboard. Now, to save the snapshot as a file, start Adobe Photoshop then press CTRL + N and then hit Enter.
This will create a blank canvas the size of the image on the clipboard. Now, press CTR + V to paste the image from the clipboard into the blank canvas. Do all the necessary editing and then save the file. And that’s it. Another way is to install Free Screen Capturer. It allows you to capture the entire screen or just a portion of it.
