Doc2Any Print Driver Installation issue on Windows 7
Hello. I am using Doc2Any in one of my application. This works nice with the Windows Vista but when it comes to Windows Seven, I get the following error.
Doc2Any attempts to create a PostScript printer for the purpose of converting the document to PDF.
And I get the following error during the creation of printer.
Please suggest a solution.
Operation could not be completed (error 0×00000705). Windows cannot locate a suitable printer driver.
Contact your administrator for help locating and installing a suitable driver.
Answered By 10 points N/A #152964
Hello Ryan,
The error could be possibly be caused by something that is related to the printer.
To resolve it, you will need to try the following:
  • You should try removing all of the printers you have installed on your computer by going to the Devices and Printers console and see if that will resolve the issue.
  • If the error still persists, you will need to go ahead and try uninstalling various applications that related to the Doc2Any application and see if that will resolve the issue.
  • If the error still persists, try installing the following hotfixes:
    • Citrix Hotfix XA650W2K8R2X64011
    • Citrix Hotfix XA650W2K8R2X64001
Carl
