Docking station issue with ipod
I have a usual docking station. When I dock there, only the right speaker works. But all the connection pins are up and running. What could be the error?
Dear Mitzi
Try plugging it to the headphone jack of your ipod to the docking stations AUX input. If sound is proper in AUX mode then there is a problem in the docking plug. First check if the dock plug is in perfect condition or not by connecting it to either an AUX input or with any other device such as a laptop with which it can be connected. If both the speakers are playing in AUX input then it means that the speakers and amplifier are working nicely and only the plug is the problem. I hope this will help. If not then you have to take the help of a professional help facility.Â
