Document Dxf objects database came out wrongly?
5 points
Posted on - 02/18/2013
Hello Good morning, I have a problem with file that are Dxf objects database. In specific location as marked on the drawing, the objects are shifted from the true position by about 50cm on the display screen. The coordinates are plotted correctly. Other objects are shown in their true position. Can someone help me with this problem.Â
