Documents form of stock takes in process
How can I make a documents form of stock takes in process? I am quite new to this and just starting to learn and it would be awesome if you could share a trick or two.
Thanks!
Thanks!
I can give you a few tips:
1) Make sure you prepare your document before the stock taking process to save time and to make sure no items are skipped.
2) You said you are just starting so using stock taking software can help you a lot or even using some templates.
3) The name of the person filling in the document should be filled in for obvious reasons like accountability.
4) All the data entered should be verified before replacing old stock document with the new one.
