Does the 9600mAh battery suits projector of Lenovo YOGA Tablet 2 Pro
It is said that a 9600mAh battery is used for a projector in Lenovo YOGA Tablet 2 Pro to play movies. But does it really suit for the tablet? Will it be able to provide 8+ hours of battery life on using the projector? Any valuable information on this battery life is appreciated.
Answered By 590495 points N/A #131949
The Lenovo Yoga Tablet 2 Pro was announced on October 9, 2014 during its global launch. It runs on Android with 13.3-inch QHD display plus an addition to its feature, a built-in projector. This makes this Lenovo tablet a unique device because this is the only tablet that is integrated with a projector that is able to beam a 16:9 image up to 50 inches diagonally.
It also comes with a 5W JBL subwoofer and two 1.5W front-facing speakers. This gives you an 8W surround sound system. The tablet’s battery will allow you to use it for up to 15 hours with only a single charge. The tablet is quite heavy weighing at around 950 grams.
The Lenovo Yoga Tablet 2 Pro is powered by Quad Core Intel Atom Z3745 processor and 2 GB RAM. It has 32 GB internal storage and a microSD card slot which allows an expansion of up to 64 GB.
