Does ActionScript 3 supported by Spaceport?
Does ActionScript 3 supported by Spaceport? If you have some ideas please leave your comments here. Thanks!Â
Hy,
Yes, Spaceport will support Action Script 3 and Action Script 3.2
You can use a converter for convert your Action Script into the JavaScript for use in everywhere that code. This software will convert or change the code from your source file. You should set up the port and other settings for does that- But that’s an easy task. So everybody will able to do that process.
At first create a zip file with your total code for convert, then upload it and then wait a moment to convert successfully. After few moments you will get output with JavaScript code.
Thanks
Hello Samara,
Go to these links to read more about Spaceport new launch:Â
https://techcrunch.com/2011/11/17/sibblingz-debuts-new-version-of-game-creation-platform-spaceport/
http://www.adweek.com/digital/sibblingz-spaceport-html5/?red=im
Hope your doubt is clear now. Regards!
