Does Ad Manager Plus support Windows XP?
I have Windows XP on my desktop. I want download Ad Manager Plus.
Yes, you can use Ad manager Plus on windows XP. But you have do download Ad manager Plus based on your operating system 32-Bit or 64-Bit.
As example if you are using 32-Bit operating system then you need to download 32-Bit, or if you are using 64-Bit operating system then you need to download 64-Bit.
You need Internet Explorer 5.5 and above or Firefox 1.5 and above versions to install the AD Manager Plus.
Also you can use add manager to the following Operating Systems:
Windows 2000, Windows 2003, Windows 2008, Windows XP, Windows
Hello Dear,
Off course you can use it windows XP. If there any problem, then please take the following steps
1. Right click on the setup file and then go for its properties
2. You can see many tabs in there. But you just need to go for the compatibility tab.
3. There will be an option named Settings
4. Now Disable the display scaling on high dpi setting
5. Bottom of that, There is a Privilege level option. Enable it and run that program as an administrator.
6. If there is problem, then run the program with above procedure
Thanks for having your time
