doriswneil
50 points
Posted on - 11/18/2012
Does anyone know if android support ape? I have not tried it, obviously and I want to know if it is possible. Currently, I do not have an android device and it would be nice if android users here could share their experience on it. Other media files supported will be nice too.
Does an android phone support ape?
Hey Doriswneil!
Yes. The robot is capable of enjoying *.ape.
This audio player is compatible in robot and is ready to run lossless files like (FLAC/APE/MPC/WV).Â
I hope this answers your question."
Hello Dear.
Yes, android support ape. There are many softwares that can play ape and other media files in android. I would suggest you to use andLess.
This is very easy to use. It also supports other media files like flac, mpc, wv etc in android. Cue sheets are also supported. You can play any lossless files in android using this.
Thank you for your question.
